CRE recording: I need to move the servers
Postby Belinda Frick » Fri Nov 04, 2016 8:34 am
The servers must be shutdown during the interface to ensure they are not compromised - if you flip the power switch it is the same as a power cut/load shedding and the servers or files may damage.
CRE recording can use 1 to 3 servers, depending on the recording solution:
  1. AMETHYST, CRE and MBG on one server
  2. AMETHYST and CRE on one server and the MBG on a second.
  3. AMETHYST, CRE and MBG each on a seperate server.
Shutdown:
If virtual servers the IT Support needs to shut down the servers in their virtual environment.
First shutdown the server via the interface if it has the option: AMETHYST Webadmin and MBG Webadmin.
Once shutdown via the webadmin interface, IT Support can shut the host down via the virtual software.
  • AMETHYST:
    How do I shut down/restart the AMETHYST server?
  • CRE server:
    If physical machine Datatex needs to log onto the server and shut it down. Alternatively if late at night organize with Datatex to run a job to shutdown server on agreed date and time:
    at -f /sbin/halt -t 201504190200
    NOTE: You need to power down the server once shut down of OS completed. Give at least 5 minutes after shut down time before powering it down.
  • MBG:
    Mitel: How do I shutdown the MSL?
NOTE:
  1. CRE recording is dependent on voice traffic.
    Make sure you re-connect the servers to the network correct so that we receive audio from the MBG to record.
