VoIPRecord: HXP does not initialize to record
Postby Belinda Frick » Mon Mar 06, 2017 3:15 pm
DESCRIPTION:
There was a power failure or the server was just powered down.
The HPX dongle does not pick up and there for no recordings.
  1. SCENARIO 1:
    Check VoIPRecord log file and if events matches:
    2017-03-06 15:01:53.912 [1.6.4.38] Starting Amethyst VoIP Recorder.
    2017-03-06 15:01:53.912 [1.6.4.38] Local IP is 10.42.51.4
    2017-03-06 15:01:53.912 [1.6.4.38]   Service thread created.  ID: 1712
    2017-03-06 15:01:53.912 [1.6.4.38]   Logging thread created.  ID: 1800
    2017-03-06 15:01:53.912 [1.6.4.38]   Settings thread created.  ID: 1716
    2017-03-06 15:01:53.928 [1.6.4.38]   AEMProducer thread created.  ID: 1840
    2017-03-06 15:01:53.928 [1.6.4.38]   Voiprecorder logging thread created.  ID: 1800
    2017-03-06 15:01:54.942 [1.6.4.38]   SmartWORKS monitor thread created.  ID: 1216
    2017-03-06 15:01:55.301 [1.6.4.38]   EarlyWarning thread created.  ID: 1220
    2017-03-06 15:01:55.301 [1.6.4.38]   EventHandler thread created.  ID: 1280
    2017-03-06 15:01:55.316 [1.6.4.38] 0 CLI rules loaded
    2017-03-06 15:01:55.316 [1.6.4.38]   AmethystHandler thread created.  ID: 976
    2017-03-06 15:01:55.316 [1.6.4.38]   DEBUG: Finding Amethyst server
    2017-03-06 15:01:55.316 [1.6.4.38]   PacketProcessor thread created.  ID: 360
    2017-03-06 15:01:55.332 [1.6.4.38]   DEBUG: Smartworks initialized
    2017-03-06 15:01:55.332 [1.6.4.38] Found HPX virtual board
    2017-03-06 15:01:55.332 [1.6.4.38]   Board status: BOARD_OK
    2017-03-06 15:01:55.332 [1.6.4.38]   Firmware version 5.7.1   Build 2863
    2017-03-06 15:01:55.332 [1.6.4.38]   Firmware version expected version 3.7.0   Build 0
    2017-03-06 15:01:56.143 [1.6.4.38] DEBUG: Processing event 1  EVT_PHY_LINK_UP (station 0)
    2017-03-06 15:01:56.533 [1.6.4.38]   Disabling station mapping
    2017-03-06 15:01:56.564 [1.6.4.38]     Error: No protocol stack (e.g. SIP) specified in configuration or stack failed to initialise.
    2017-03-06 15:01:56.564 [1.6.4.38] Error in SetupBoards: Could not initialise HPX virtual recording card.
    NOTE ENTRY: Error: No protocol stack (e.g. SIP) specified in configuration or stack failed to initialise.
    This means it has no 'settings' to load.
    Please check VoIPRecord.ini file that settings did not default:
    [OPTIONS]
    SERVER=
    FORCESERVER=0
    [FAILOVER]
    MASTER=1
    LISTENPORT=37002
    OTHERHOST=10.42.51.5
    OTHERPORT=37003
  2. SCENARIO 2:
    2019-07-05 08:55:28.012 [1.7.1.3] Error: No protocol stack (e.g. SIP) specified in configuration or stack failed to initialise.
    2019-07-05 08:55:28.012 [1.7.1.3] Error in SetupBoards: Could not initialise HPX virtual recording card.
    The PROTOCOL must be set:
    [PROTOCOLS]
    ALCATEL=0
    AVAYA=0
    SIEMENS=0
    SIP=0
    CISCO=1
    LGNORTEL=0
    NOTE: Required PROTOCOLS must be set to 1. To activate it, you need to restart the service.
