I have installed AMTListen on Windows 10.
I have installed Firebird 2.5.5.26952 64-bit.
I can log into AMTListen, connect to the database.
When I select the extracted database it gives an error that it cannot find the fbclient.dll.
I can see a fbclient.dll in the same folder as the AMTListen executable.
Solution:
Please use the attached fbclient.dll
You need the 64-bit Firebird service to run, but the 32-bit fbclient.dll to talk to the database via AMTListen(32-bit)
