How do I delete recordings from AMETHYST 1.4?/I need space
Postby Belinda Frick » Wed Nov 17, 2010 1:07 pm
In AMETHYST 1.4 there is no purge facility. You need to make a
backup of the recordings, before those recordings can be moved
to a different drive.
Make a backup of the recordings:
You can backup the data to another drive (the recordings is not
removed from the AMETHYST database on the server).
ALSO SEE: Backup procedures in Amethyst 1.4
ALSO SEE: Amethyst backup procedures
Move the recordings to another drive:
To remove the recordings from the AMETHYST database, you must
use the AMTRSMOVE program. This will move the recordings to the
removeable harddrive. There is a version for Windows and for
Linux. The Windows version is available on the internet.
ALSO SEE: How to use amtrsmove.exe
Listen to the recordings on another drive:
To listen to the recordings that has been moved, insert the
removeable harddrive and use the normal search facility.
