SIPRecord 1.7.0.21: add extension for recording with Alcatel
Postby Belinda Frick » Wed Jun 13, 2018 1:09 pm
STEPS:
  1. Check if enough licenses to add extensions for recording.
    Add recorded extensions to AMETHYST Devices List.
    Checking and modifying Amethyst licenses
  2. Update Configure Virtual Extension with the User names and Extensions.
    How do I setup Virtual extension in AMETHYST ?
  3. The ini files must be updated and then the recordings software restarted to apply.
    NOTE: This must be scheduled outside recording hours as it will cut recordings and not start recording until software started up and stations loaded for recording.
    SUGGESTION:
    First prepare the ini files.
    Organize restart time and then replace the ini once software stopped.
    • Confirm siprecord.ini:
      1. Code: Select all
        [OPTIONS]
        RECORDALLEXT=1
        RECORDALLIP=1
        PERMANENTSTATIONS=1
        NOTE: Where is my changes to the Stations.ini file?
      2. Recording solution (PABX):
        [ALCATEL]
        ENABLED=1
      3. All extensions to be configured must be listed under:
        [EXTENSIONS]
        For example:
        [EXTENSIONS]
        12904=
        12906=
        12919=
    • Confirm stations.ini
      1. All IPs op recorded phones must be listed under:
        [PHYSEXT]
        For example:
        [PHYSEXT]
        10.51.241.222=
        10.51.241.87=
        10.51.242.102=
      2. All user names must be updated under :
        [STATIONS]
        For example:
        [STATIONS]
        0=10.51.241.222|12904|Princess Thwala
        1=10.51.241.87|12906|Cynthia Nqidi
        2=10.51.242.102|12919|Melissa Jonker
  4. Update recording software with prepared ini files:
    • Disable the checksip scrip in the crontab:
      crontab -e
      #Checksip
      * * * * * /usr/local/bin/checksip.sh
      Place # infront to comment out:
      #Checksip
      #* * * * * /usr/local/bin/checksip.sh
    • Run the stop SIPRecord script:
      ./stopsiprecord
    • Update the 2 ini files:
      siprecord.ini
      stations.ini
    • Remove the '#' from the crontab
    • checksip will then startup the SIPRecord again - monitor with tail -f siprecord
Re: SIPRecord 1.7.0.21: add ext for recording with Alcatel
Postby kebogile Porogo » Fri Jun 22, 2018 2:53 pm
Additional Steps To Add Extensions For Recording.
After verifying available licences.
    1. Make a backup of the live siprecord.ini file before making changes, whilst in the siprecord directory
    root@micloud:~# cd /opt/datatex/siprecord
    2. Copy siprecord.ini to siprecord.new
    root@micloud:/opt/datatex/siprecord# cp siprecord.ini siprecord.new
    3. Edit the newly copied siprecord.new 'EXTENSIONS' section with the new extensions to be recorded.
    root@micloud:/opt/datatex/siprecord# vi siprecord.new
    [EXTENSIONS]
    +27118443200=
    +27874054641=
    +27874054642=
    +27874054643=
    Write & Quit to save the changes made
    4. Recload the siprecorder either by running reloadsip.sh or telnet to 127.0.0.1 27007, and reload.
    root@micloud:/opt/datatex/siprecord# telnet 127.0.0.1 27007
    Trying 127.0.0.1...
    Connected to 127.0.0.1.
    Escape character is '^]'.
Siprecorder will reload the settings from the siprecord.new file and new etxensions will be monitored for recording.
kebogile Porogo
Postby kebogile Porogo » Wed Jul 18, 2018 10:04 am
Update: THE BELOW RELOAD PROCEDURE DOES NOT RELOAD THE STATIONS.INI FILE.
Reload will load changes made in the siprecord.ini
With Alcatel setup, the siprecorder will need to be restarted as well.
kebogile Porogo wrote:Additional Steps To Add Extensions For Recording.
    [EXTENSIONS]
    +27118443200=
    +27874054641=
    +27874054642=
    +27874054643=
    Trying 127.0.0.1...
kebogile Porogo
