If your server stops working and then you start it up again and it works for a
while before shutting down again, please check the CPU fan.
If the CPU fan stops working after a while, the CPU will overheat and the server
will stop working.
If something gets stuck in the fan, it will also slow the fan speed down.
It has also been reported that the glue of the sticker on the CPU heated up and
the sticker slipped into the fan. After the fan has been running a while the
glue inside heats up to get sticky and then slows the fan down.
This is a possibilty with any Datatex Server.
