iRecall Supervisor: autocomplete off
Postby Belinda Frick » Tue Sep 10, 2019 12:22 pm
Amethyst Supervisor 2 version 2.0.1.13 has a new feature.
The partial number search option is now available again.
You can now search only part of the number - leading, trailing or part of the number.
For this reason the information 'autocomplete off' is displayed for the number field only.
You can still search for the full number.
If you then enter for example the user name - it will have the auto complete feature:
it will display the list of user that has calls for this number.
