Install the AMTLink.exe COM object into the correct folder.
This will be C:\Program files\datatex\USBClient\ for the USBClient
and C:\Program files\datatex\SLVR\ for the SLVR.
Open a DOS prompt and navigate to the location of the AMTLink.exe COM object.
Enter the command : AMTLink.exe /regserver
Open the Delphi IDE and click on the Project menu option.
Choose the Import type library menu option.
In the list of type libraries there will be a Amethyst Linker Library
Install the COM object and use to integrate with Amethyst.
