When using AMETHYST 1.5 the recommeded setup is using SMDRLink for call data. The area
code is setup in SMDRLink.
In earlier versions of SMDRLink the area selected needed a database file for that area.
Getexchange was used with the database is the first versions.
The latest versions uses GetSet. No database is needed.
ALSO SEE: How do I setup GetSet with SMDRLink (Windows)?
How do I check if the correct area is setup for AMETHYST?
ALSO SEE: AMETHYST Administrator: Change area code
