Checking if SMDRlink webadmin is set up & receiving data
Postby Belinda Frick » Wed Nov 17, 2010 3:42 pm
Login to the SMDRLINK from AMETHYST webadmin:
AMETHYST Webadmin Home page, click on 'Configure SMDRLink' option.
The default login and password is:
    Login : admin
    Password: datatex
In the General Settings section, check if the log level is set to 'all'.
If not, please select all.
Cick on 'Apply Changes'
To view the call details:
Click on the 'View Logs' icon.
Click on 'SMDRlink detail log'.
Click on 'Today'.
You should now see call data on the page.
(See example of SMDRLink detailed log below - make sure logging is set to 'ALL')
[2007-01-23 14:57:28.946] getPBX <== 23-01-2007|15:03:15|110|0215924037|I||00|00|18|7|I_NORMAL|0|0|
[2007-01-23 14:57:28.946] getPBX ==> 23-01-2007|15:03:15|110|0215924037|I||00|00|18|7|I_NORMAL|0|0||
[2007-01-23 14:57:28.946] Plugin data = 23-01-2007|15:03:15|110|0215924037|I||00|00|18|7|I_NORMAL|0|0||
[2007-01-23 14:57:28.946] SMDR data [R:110|0215924037||0:00:18|R0.00|2007-01-23|15:03:15||7|I|RECEPTION|]
In the example the line with 'getPBX <== ' is the rawdata received via the comport, if the 'end
of line character' specified was detected.. The next 2 line is processed untill the 'SMDR data '
line show the SMDR data that will be used to tie to the recording. Please note that for each call
made you need to receive all 4 data lines in SMDRLink, else you will not have call detail for that
recording. You must have the 4th line with the entry "SMDR data [R:", "R:" is followed by the extension number.
If you do not see data in SMDRlink Detailed log, check the SMDRLink status log for errors.
SMDRLink receives call details via:
  • Network:
    Confirm PABX IP and port configuration.
  • Serial cable:
    Ensure SMDR cable is connected between the SMDRLink PC and the PABX unit.
