Required
amt-usbclient-install-1_5_0_12.exe available from datatex support on request.
Updates are available on www.datatex.co.za.
Installation
Run the amt-usbclient-install-1_5_0_12.exe on each client PC.
Make sure the USB tap is connected correctly to the PC and is detected by Windows.
Do not adjust the ini file, except for the extension number and AMT server.
For Trouble shooting
See documents:
Trouble shooting: USBclient problems
My USB tap is not working
Amethyst Recording Issues using USBClient
