FIXES
If you are using Firefox to view Amethyst, the tool tips do not diplay.
On the license screen of the webadmin,the current license status is displayed.
Amethyst uses the concept that it will expire on the last day of next month after
it was installed. The display label does not display correctly, from 30 days after
the installation, it willdisplay that Amethyst has expired.This is only a display
problem, because Amethyst still works correctly and expires on the correct date.
"Test connection" button in Archive Settings succeeds even if the NFS drive
fails to mount.
In addition to NFS and harddrive backups, the configuration should list "dual" as an option
in the configuration screen.
An entry must be written to the webadmin log when this option is changed.
When purging, the webadmin must check all changelog files. Changelog files will be located
in /opt/amethyst/bin/, /opt/amethyst/bin/hdd/ and /opt/amethyst/bin/nfs/ and will have names
with the format change.log*.
There are two csv files that can be exported. The AQM for yesterday and the processed
calls for yesterday. If there is a email address for the AQM csv export, the Webadmin will
check for both files. The checking to export should be done on each separate email address.
