AMETHYST 1.5: Export reports from AMT in .csv
Postby Belinda Frick » Thu Nov 18, 2010 8:40 am
Comma seperated values .csv files are not supported by AMETHYST to export and import
AQM templates. However, templates can be exported and imported into AMETHYST
in the *.tpt format. Please note the format. lowercase for the extension.
AQM templates:
To export the AQM template simply:
Go to the 'AQM Template configuration' screen in AMETHYST Administrator.
Click on the template you want to export.
Select the 'Download template' link.
For earlier version than 1.5.8.0 change the file format to all files and add the
extension '.tpt' at the end of the file name.
Reporting on AQM views:
Reports can be emailed from the supervisor, if the mail server is setup correctly, and
is emailed in html format. Make sure that your email client accepts html and can read it.
You can view the report and then save the page in html.
Alernatively all the AQM reports, the scoring can be sent to via email.
That would be in a *.csv file format for ease of import to third party databases of software.
