Critical error: Error unmounting local backup drive
Postby Belinda Frick » Thu Nov 18, 2010 10:09 am
When you check the AMETHYST admin log and it has the following detailed logging for the error:
[2007-06-10 21:00:01] Version [1.5.11.0]Starting incremental backup (PID 5180)
umount: /opt/amethyst/backup/hdd: device is busy
[2007-06-10 21:01:30] Version [1.5.11.0]Error unmounting local backup drive: Operation not
permitted
[2007-06-10 21:01:30] Version [1.5.11.0]Done incremental backup (PID 5180)
Please note:
The PID is the same number in the "Starting.." and "Done.." entry.
The follwing is also logged "umount: /opt/amethyst/backup/hdd: device is busy ".
If this is the case then, the archive was successfull.
This will be addressed in a future release of AMETHYST.
