The AMETHYST archive drive
Postby Belinda Frick » Thu Nov 18, 2010 10:40 am
This document only relates to older hardware that still used the IDE internal brackets.
New Drive:
When using a new drive for archving, simply place the unformatted drive into
the tray and use the AMETHYST webadmin option to initialize the drive.
Existing Drive:
Harddrive jumper settings must not be change if you remove the drive to check
it under windows. To ensure that this did not happen, Datatex has a tool that you
can run to check what the server expects.
