Windows Vista and the USBClient
Postby Belinda Frick » Thu Nov 18, 2010 11:03 am
The Vista firewall can block UDP packet being sent. It will allow the
initial broadcast, AMETHYST will display STANDBY. It will thereafter
time out and the display will change to DOWN.
If you disable the firewall the UDP packets will be allowed.
