AMETHYST has a static IP. In AMETHYST webadmin under
'Configure Network' you can see the server IP and the
hostname.
Ping the AMETHYST server
Reply from 192.168.15.10: bytes=32 time<1ms TTL=64
Then do an
arp -a command
It will show the corresponding IP address with the MAC of that IP.
Interface: 192.168.15.77 --- 0x2
Internet Address Physical Address Type
192.168.15.6 00-18-4d-e9-d6-58 dynamic
192.168.15.8 00-18-4d-e9-db-f7 dynamic
192.168.15.9 00-18-4d-e9-db-f8 dynamic
192.168.15.10 00-03-47-31-d1-24 dynamic
192.168.15.16 00-16-76-4f-c3-97 dynamic
192.168.15.61 00-18-4d-e9-d2-40 dynamic
192.168.15.66 00-0f-ea-55-72-26 dynamic
192.168.15.71 00-18-4d-e9-d6-59 dynamic
Please note: If you have a duplicate IP on the network:
First check if you can log into AMETHYST webadmin. Then you
know that the IP is now pointing to the AMETHYST server,
therefore you can run the 'arp -a' command to get the MAC
address as explained above.
Once the AMETHYST webadmin is not accessible any more, you can
then run the 'arp -a' command to get the MAC address of the
duplicate IP.
Make sure AMETHYST IP is not used on the network.
