Test connection error:Fail to mount drive/mounting test fail
Postby Belinda Frick » Thu Nov 18, 2010 11:19 am
fail to mount drive
mounting test failed
mount: wrong fs type, bad option,bad superblock on dev/hda1
missing code page or other error
(are'nt you typing to mount an extended partion
instead of some logical partition inside?)
In some cases usefull information is found is sys log - try
dmesg|tail or so
Under investigation!
