by Belinda Frick » Thu Nov 18, 2010 11:31 am
The 'stop' and 'start' of the recording are controlled by the recording cards.
- LDA (used for recording of analogue extensions and analogue trunks.
- Extension side recording: The calls will be sliced when transferred as the recording card identifies the channel (device) that is being recorded.
The following detail will always be displayed (even without SMDR data)
Date
Time
Duration
Extension number
Please note: There will be no telephone numbers stored with the recordings.
- Trunk side recording: The calls will not be sliced when transferred as only 1 channel is being recorded.
Date
Time
Duration
Telephone number (PABX must send DTMF signalling/CLI)
Please note: There will be no extension numbers stored with the recordings.
- NGX (used for recording of digital extensions and BRI trunks).
Date
Time
Duration
Extension number
Telephone number if the PABX sends it to the phone
Date
Time
Duration
Telephone number (There must be CallerID)
- DP (used for recording of PRI lines)
Date
Time
Duration
Telephone number for outbound calls. Inbound calls if Caller ID is enabled.
