AMTCards version 1.6.2.25 (encrypted)
Postby Belinda Frick » Thu Nov 18, 2010 12:52 pm
Version 1.6.2.25
  • "Recording too long" warnings are only sent once per recording.
  • Added a feature for forcing the direction on PRI channels to be outgoing.
    The setting for forcing the direction looks like this:
    [FORCEDOUTGOING]
    2_1=1
    2_2=1
    2_3=1
    where 2_1 is the pcislot/channel, same as the AMTCHANNELS and CHANNELS_NAMES sections.
    You only enter the channels where you need this setting, FORCEDOUTGOING is off by default.
Note: For use with AMETHYST 1.6 only.
