AMTCards 1.6.2.38(encrypted)
Postby Belinda Frick » Thu Nov 18, 2010 1:02 pm
Framer alarms for NGX cards are no longer armed if the channel
is not enabled.
For Alcatel 4400, if the virtual extension is available, the physical
extension is copied into the PhysExt field of the DTA structure.
Added a new feature: CTIMode. This allows software (currently TSAPI_Avaya)
to start and stop recordings on extensions and trunks. When in this mode,
the cardserver will not start recording on its own. Part of the start
information contains extension, telephone and trunk.
Fixed bug in Samsung 7200 - it previously stopped recording when two
"stops" were received, regardless of the fact that a "start" occurred
between the two "stops". Now it requires two consecutive "stops" to
stop recording. This fixes a bug where if they press a digit to start
dialing and it sends a stop and a start. Then, when the
phone is answered, it sends a stop, and the cardserver stops recording.
Fixed bug where live listening on AMTClients was not working
(requires server version 1.6.0.30).
Gain / Volume setting to 0 dB is no longer logged.
Number matching is now written to the INI file.
The AudioRecv channel object was updating the status twice when a
recording started.
All thread IDs are now logged at startup when in debug mode.
