Below is changes listed for 1.2.10(encrypted), this also applies for
1.2.9(unencrypted).
Version 1.2.10.22
Includes new MiTAI DLLs
Version 1.2.10.21
Log file names are now in lowercase on Amethyst servers.
Amethyst "appstatus" utility can now query AMTMitel version (INI file).
No longer prints "dtxMitel.dll" if libmtai.so cannot be found.
Version 1.2.10.20
Better support for multi-call groups.
Fixed bug where the CLI rules do not delete properly if the TCP "RELOAD"
is used and a rule has been deleted. The sample CLI rules didn't have a
terminating pipe, so if you made them active, the "OUTGOING ; comment"
would be changed to ANY, since it was not just the word "OUTGOING" or
"INCOMING".
Version 1.2.10.19
Added code to support trunk and extension ranges in the INI file.
Version 1.2.10.18
Added support for multi-call groups (only monitoring first member at
the moment). Added support for adding new devices and controllers
while AMTMitel is running - deleting devices and controllers is not
yet supported.
Version 1.2.10.17
Automatically strips # off the end of telephone numbers.
Version 1.2.10.16
CallDelivered handler defaults calls to Unanswered.
Added code to start a new call when conferencing is used to transfer
a call .
IsIPTrunk now checks if multiple controllers are monitored.
IsMonitoredTrunk now checks all controllers for monitored trunks.
Split dtxMiTAI into functions and types, to make it easier to write
debugging code that simulates a Mitel.
Log writing is now faster.
