How do I access AMETHYST supervisor via the internet?
Postby Belinda Frick » Thu Nov 18, 2010 1:38 pm
The Amethyst server must have access to the Internet
(default gateway must be configured). Depending
on your network setup, this may involve configuring your
router / firewall with port forwarding and possibly NAT
(Network Address Translation).
Options:
Internal IP addres:
If the Amethyst server has an internal IP address (addresses in
the range 10.x.x.x, 172.16.x.x to 172.24.x.x, or 192.168.x.x)
then both NAT and port forwarding will be required. Set up the
router / firewall to forward both port 80 and port 443 to the
Amethyst server. Browse to the router / firewall IP address,
and you will have access to the Supervisor.
Internet addressable IP address:
If the Amethyst server has an Internet addressable IP address
(i.e. it's not an internal IP address), then only the firewall
will need to be changed to allow access to ports 80 and 443.
Browse to the Amethyst IP address, and you will have access to
the Supervisor.
