How do I remove and add a physical device in AMETHYST 1.6?
Postby Belinda Frick » Fri Nov 19, 2010 10:43 am
  1. Remove extension
    AMETHYST Webadmin -> Configure Recorded Devices
    By default the Physical Device List is sorted by extension, find the extension you want to remove. Under the 'Deactivate' heading, tick the option 'tick to deactivate'.
    Note that once deactivated, you can only enable it after 7 days again.
    Click on APPLY.
    You will return to the Home page.
  2. Add extension
    Click on the Add extension button. Enter the extension number.
    Click on APPLY.
  3. Reprocess rejected calls (last 5 days).
    If the extension was in use and configured to record before you added it to the device list, you can reprocess the rejected calls.
    AMETHYST Webadmin -> Reprocess calls
    Click on Process
  4. If any recordings was made for this extension and rejected the reprocess will load it, else make a test call and check for 'Last Recording' on the List of recorded devices.
