Which plugin do I use for the NEC SL1000?
Postby Belinda Frick » Fri Dec 02, 2011 12:54 pm
  • Please see forum post:
    PABX3 PLUGIN: NEC 96i Revision 2
    For TCP port to receive call details configure:
      mode 10-20-05, the SMDR Output value must be configured - default 4001
      if not configured it could be that it is no setup under firstparty tapi
      mode 10-20-09
      Correct this setting to allow SMDR data.
  • On some of the NEC SL1000 the rawdata format is different. It is the same as the IP output for the NEC IPC 500.
    Please use the NEC Aspire plugin. For details and plugin file please refer to forum post:
    Which plugin do I use for the Philips IPC 500?
Last edited by Belinda Frick on Wed Aug 01, 2012 10:19 am, edited 1 time in total.
Re: Which plugin do I use for the NEC SL1000?
Postby gerrie » Mon May 14, 2012 2:05 pm
I have installed the plug-in and the call data shows on the onfo bar at the right botom of the screen.
No info shows on the raw data screen
Plug-in shows correct version
Have attached raw data file as all received data show. New data appear on the bottom of the list.
Data from the raw data file:
POT 13:25 002 00:00:03 201 1026
POT 13:27 004 00:00:00 201 1026
POT 13:27 005 00:00:04 201 0800777777
POT 13:28 001 00:00:03 201 0800123456
POT 13:32 002 00:00:00 201 1026
POT 13:42 004 00:00:00 201 0849209293
POT 13:44 005 00:00:00 201 0849209293
gerrie
Postby Belinda Frick » Mon May 21, 2012 10:01 am
Your rawdata does not have the sequence number. Please see post with example of rawdata.
