Dear Nicky
As discussed telephonically. Log into TNG - Call Cost Calculator and check the cost of one of the numbers that are not costed on the TNG report.
Please follow steps below to check the cost of a specific number:
TNG-> Home page -> Call Cost Calculator -> Call Criteria:
1.) Use the number from the TNG Report or the Call List page, replacing the country code with zero under Calculate Cost. For example: 27215924033 -> 0215924033
2.) Enter the duration,
3.) Select the date and time,
4.) Select the ratebook (e.g. za_telkom),
5.) Click on Calculate Cost.
If a cost is displayed here, you can do a re-cost of calls.
SEE: How do I re-cost calls?
How do I recost calls in TNG?Please click on link below to access complete post:
Why is my outgoing calls costed at zero?Yours Sincerely
Odette
