by Makhado » Wed Jan 02, 2013 8:35 am
Hi
I have a problem with my TNG Call Barring, it does not run barring logs any more, all systems are connected and running, i also restarted the PC many times but with no result.
Makhado
by Belinda Frick » Mon Jan 07, 2013 12:44 pm
First step is to check that TNG is receiving call details live in TNG.
- Log into TNG.
- Go to the TNG 'Call List' page.
- Make a test call and check on the 'Call List' page if the call is displayed when you terminate the test call.
NOTE: This must be an outgoing call with a duration so that it will have a cost displayed. If you use pin code barring the test call must be made using a pin code, if extension side barring is used you must make a test call using an extension. If pin code barring, it must have a user name and if extension side barring it must have a extension description.
