Hi
I have TNG v1.0.7.0 running at a client and CDR importing seemed to have stopped. The call list view shows the last call on the 8th of Nov 2012.
If I look at /var/log/asterisk/cdr-custom/Master.csv I can see it is still logging fine since all the way.
I tried forcing TNG to load the cdr data, by extracting all the calls for December into a seperate csv file and pointing the CSV file location to it, nothing happened. I then pointed it back to the Master.csv and it is still stuck on the 8th.
I tried doing the "Synchronize data" too, but no luck.
Where can I start looking to get it working again?
