New Version, 1.1.1.11, not working in Swaziland
Postby thembanxumalo » Thu Apr 04, 2013 11:18 am
Hi have installed version 1.1.1.11 on two different pc's for my clients and have had no luck getting it to work. The installation is done correctly but for some the windows service will not startup.
I resorted on one of the installations to use the older version 1.1.0.5 and this worked without a glitch.
Please Help
thembanxumalo
Re: New Version, 1.1.1.11, not working in Swaziland
Postby Odette Danster » Mon Apr 08, 2013 9:10 am
Dear Themba
As discussed telephonically.
Please use link below to access the forum post.
TNG with buffer executable version 1.1.1.11
Kind Regards
Odette
Odette Danster
Postby Odette Danster » Wed Apr 24, 2013 5:31 pm
Dear Themba
We have been discussed your query and need more information regarding the individual installations. You mentioned that the software was installed on different Windows versions.
If possible, could you please check the Windows Event logs for any error messages for the day you ran the TNG v1.1.1.11 update? Please check the logs for both Windows versions and sent a screenshot of the error.
Can you also check and confirm if TNG is costing calls? Which version of TNG is currently installed at the clients?
Thanking you in advance.
Kind Regards
Odette
Odette Danster
Postby Thembinkosi Nxumalo » Thu May 02, 2013 9:46 am
Hi,
Have attached a copy of the log file for the problem i am having with TNG version 1.1.1.11
Thembinkosi Nxumalo
Postby Odette Danster » Thu May 02, 2013 11:06 am
Dear Themba
I downloaded the log file and upon investigation I found that the log has today's date (02-05-2013).
Unfortunately this log file does not contain the details we require for our investigation. Could you please attach the tng.log for the day you ran the update?
We have to check the log entries the software created when it was updating to v1.1.1.11. Please also check if you have an extract.log file located in C:\Program Files\Datatex\tng\update directory.
The event logs created by Windows might also have error messages - please check if you have any entries for the TNG software. NB: It must be for the day you ran the update on the PC/Server.
Please accept our sincerest apologies for any inconvience caused.
Kind Regards
Odette
Odette Danster
Postby Thembinkosi Nxumalo » Mon May 13, 2013 3:53 pm
Hi I hope this si the info yu wanted from me. this is from a windows 7 machine
Thembinkosi Nxumalo
Postby Odette Danster » Tue May 14, 2013 9:24 am
Dear Themba
Thank you for sending us the file.
We will use the information to simulate your problem. The tests will be conducted on different windows operating systems.
Once complete, I will provide feedback.
Kind Regards
Odette
Odette Danster
Postby Belinda Frick » Thu May 23, 2013 9:28 am
I saw some entries in the tng.log file relating to the exchange file:
2013-03-20 18:20:55:328 [1.1.1.11] - Exchange Library      : Verifying Versions...
2013-03-20 18:20:55:344 [1.1.1.11] - Error with MD5 : Cannot open file "C:\Program Files\datatex\tng\exchange.dat". The system cannot find the file specified
2013-03-20 18:20:55:344 [1.1.1.11] - Exchange Library      : exchange.dat Changed!!
2013-03-20 18:20:55:360 [1.1.1.11] - Exchange Library      : DLL has Changed!!
2013-03-20 18:20:55:360 [1.1.1.11] - Exchange Library      : Recreating Library [ver 2009.08.03.01] for source number 26825185537
2013-03-20 18:20:56:982 [1.1.1.11] - Exchange Library      : Recreating Failed!
Please attached the tng.ini file. I need the area information to install a TNG with your settings to see if it gives the same entries.
Postby Thembinkosi Nxumalo » Thu May 30, 2013 9:34 am
Please find attached ini file
Regards
Thembinkosi Nxumalo
Postby Belinda Frick » Fri Jun 14, 2013 9:53 pm
Dear Themba
I did install a test TNG(with buffer) version 1.1.1.11 for Swaziland using your area information.
After install, it searched for buffer and never got to the login screen. The TNG service was running. I stopped/started the TNG service, thereafter I could open the TNG login page. After entering the login details it seems to get stuck. The TNG service is still running. I also get the same log entries as yourself - referring to the exchange file. The TNG shows it is for Swaziland as the country.
We will need to discuss this further internally to give you feedback towards a solution. Please note that Monday 17 June 2013 is a public holiday in South-Africa.
Regards
Belinda
Next
