View old reports on TNG
Postby Century » Mon Apr 29, 2013 12:12 pm
Good day.
We can't view old reports since our re-registration of our TNG software.
The software shows my old phonebook and old user account data. My extension configurations data was lost, but I re-populated that. So the current call list seems to show everything correctly.
If I go to datatex\tng\logs, I can see the older date folders with the raw.txt files in each, but I can't pull reports from the TNG software from those dates. Is there a way I can import that raw.txt data?
Century
Re: View old reports on TNG
Postby Belinda Frick » Mon Apr 29, 2013 3:11 pm
If you have missing ranges of data you can either import these ranges or blank the TNG database and import the period of data you require.
