Rates
Rates
Postby Frankbetz » Sat Jun 01, 2013 7:42 am
How do I? "Please have the following rates programmed in to Topaz and TNG on the ComX. "
Local = 29 cents
National = 45 cents
Cell C = R1.11
Vodacom / MTN = 96 cents
Telkom R1.17
All ex vat
Frankbetz
Re: Rates
Postby Belinda Frick » Mon Jun 03, 2013 10:51 am
To setup Custom rates in TNG refer to forum post:
Re: Zones to use for TNG and Custom rates
To ensure your TNG has all the latest prefixes (for example 8TA), else it will cost that call at zero - please upgrade to the latest version.
For newest release of TNG version 1.1(as of 20130603) see forum post:
last TNG releases for 2012
Re: Rates
Postby Frankbetz » Wed Jun 05, 2013 7:34 am
Please could you check my attached and see if I have done it correctly?
Frankbetz
Re: Rates
Postby Belinda Frick » Wed Jun 05, 2013 11:32 am
For TOPAZ rates update refer to forum post:
Were do I find TOPAZ rates for ZA updates after 2009?
Re: Rates
Postby Belinda Frick » Thu Jun 20, 2013 5:34 pm
Please try the following:
  1. Stop the TNG daemon.
  2. Navigate to '/opt/datatex/tng/rates/'
  3. Rename you custom rates file to for example .old.
  4. Navigate to '/opt/datatex/tng/rates/custombase'
  5. Copy the 'custom.so' file from the custombase folder to the 'rates' folder.
  6. Navigate to '/opt/datatex/tng/rates/'
  7. Rename the 'custom.so' file in the rates 'folder' to the same name as your custom rates file (the one you renamed).
  8. Start the TNG daemon.
  9. Do 'Test Cost Calculation' and check if the rates are now correct.
Re: Rates
Postby Belinda Frick » Wed Jun 26, 2013 10:37 am
I duplicated your zero costing when using 1.1.1.11.
To fix it you need to update the custom rate file - refer to topic
after upgrade Custom rates cost at zero
Our apologies for the inconvenience.
Re: Rates
Postby Frankbetz » Wed Jun 26, 2013 3:21 pm
See TNG.ini
Frankbetz
Re: Rates
Postby Belinda Frick » Thu Jun 27, 2013 9:41 am
Thank you for the ini.
We will setup a test TNG using the area information.
Re: Rates
Postby Belinda Frick » Mon Jul 01, 2013 4:47 pm
We setup a test TNG on Windows using your regional settings.
It costed calls using the default Telkom ratebook.
When we did the all_custom.dll update and it costed the custom rate book.
We must now schedule time to log onto the TNGLive (Asterisk on COMX) and investigate why it costs the custom rate at zero after the 'custom.so' update.
Re: Rates
Postby Belinda Frick » Wed Jul 03, 2013 3:56 pm
We have logged in yesterday and re-did the steps sent to you.
The cost for custom ratebook is still zero.
We will have to discuss it internally.
Next
