rossnet outgoing call problem
Postby rossnet » Mon Aug 05, 2013 11:55 am
outgoing calls not registering
rossnet
Re: rossnet outgoing call problem
Postby Belinda Frick » Mon Aug 05, 2013 1:14 pm
I ran the rawdata with the plugin in the post:
PABX3 Plugin:Phillips NEC IPC100 software 7.0H release 5.0.1
It showed Outgoing calls and the phone numbers - see screenshot:
NOTE: There are very few incoming calls in the rawdata.
Please ensure you are using
  1. Plugin: PNEC_IPC100_S70H_R501.dll
  2. Plugin version: 2009.09.01.1
