NEC XN 120 with CLI
NEC XN 120 with CLI
Postby ComPos » Wed Aug 21, 2013 1:56 pm
18 PIN 13:36 21/08 008 00:00:27 237 0217977310 0:05
19 PTRS 13:36 21/08 008 00:01:14 215 0217977310 0:05
20 POT 13:38 21/08 007 00:00:00 215 08611143
21 POT 13:38 21/08 008 00:00:46 215 0861114351
22 POT 13:39 21/08 009 00:00:45 215 0861114351
23 POT 13:40 21/08 010 00:00:00 215
24 PIN 13:40 21/08 006 00:00:24 237 0837990777 0:05
25 PTRS 13:41 21/08 006 00:00:04 215 0837990777 0:05
26 POT 13:41 21/08 001 00:00:46 215 0861114351
27 POT 13:42 21/08 002 00:00:56 215 0215924033
28 POT 13:43 21/08 003 00:00:50 215 0861114351
29 POT 13:45 21/08 004 00:00:50 215 0861114351
30 POT 13:47 21/08 005 00:00:00 215 0886
31 POT 13:47 21/08 006 00:00:49 215 0861114351
32 POT 13:51 21/08 007 00:00:00 215 0861114651
33 POT 13:51 21/08 008 00:00:45 215 0861114351
34 POT 13:54 21/08 009 00:00:49 215 0861114351
35 POT 13:54 21/08 010 00:00:47 215 0861114351
36 POT 13:58 21/08 001 00:04:17 215 0861114351
37 POT 14:02 21/08 002 00:00:30 215 0837990777
41 POT 14:08 21/08 004 00:01:13 215 0861114351
42 PIN 14:11 21/08 001 00:00:46 237 0116786561 0:05
43 POT 14:16 21/08 006 00:00:13 271 0835042259
44 POT 14:16 21/08 007 00:00:25 264 0217973528
ComPos
Re: NEC XN 120 with CLI
Postby Belinda Frick » Wed Aug 21, 2013 2:35 pm
I used the plugin version in forum post:
PABX3 Plugin:Phillips NEC IPC100 software 7.0H release 5.0.1
See settings in TNG under 'General Settings' and 'Communication Configuration:
Below is the 'Call List' page for your rawdata and the plugin 'PNEC_IPC100_S70H_R501.dll', version '2009.09.01.1:
NOTE: The entries in the 'Trunk' column is correct.
See rawdata, the LINE numbers match that of the 'Trunk' column on the TNG Call List page :
  CLASS  TIME DATE  LINE DURATION  STATION   DIALLED No.CLI  RDCOST ACCOUNT
