Telkom not costing
Telkom not costing
Postby Dcdata » Thu Sep 05, 2013 12:56 pm
Hi am having a issue where all outgoing calls through a telkom trunk are not costing. The sip trunk works fine. Attached is the call made to our office the number is 0333446100. What I have noticed is that somehow its not picking up the destination of calls.
The csv log shows the following.
cat /var/log/asterisk/cdr-csv/Master.csv
"","300","0333446100","from-internal","300","SIP/300-00000721","SIP/5000-00000722","Dial","SIP/5000/0333446100,300,","2013-09-05 08:12:13","2013-09-05 08:12:16","2013-09-05 08:13:46",93,90,"ANSWERED","DOCUMENTATION","1378368733.1981","audio:OUT300-20130905-101213-1378368733.1981.wav
Strange enough though is that calls through the sip trunk are fine. Is it perhaps the name of my trunk that causing issue here?
Attached are the screen shots
Dcdata
Re: Telkom not costing
Postby John Richard Procter » Thu Sep 05, 2013 3:20 pm
Dear DCdata
Could you please provide the tng.export file and master.csv.
We need this for further investigation.
Kind Regards
John-Ri
Postby Dcdata » Fri Sep 06, 2013 8:45 am
Hi
Attached is the Master.csv file. May I ask where do I locate/find the tng.export file?
Dcdata
Postby Belinda Frick » Fri Sep 06, 2013 2:57 pm
The export files is located in the folder:
/opt/datatex/tng/export
Postby Dcdata » Fri Sep 06, 2013 3:53 pm
Belinda Frick wrote:The export files is located in the folder:
Hi Belinda
This folder is empty.
Dcdata
Postby Dcdata » Mon Sep 09, 2013 1:34 pm
Hi
Attached is the requested files
Dcdata
Postby Belinda Frick » Fri Sep 13, 2013 4:20 pm
Thank you.
We will investigate the logs
Postby John Richard Procter » Mon Sep 16, 2013 2:39 pm
    Dear DC data
    We have loaded your trunk configuration and Master.csv
    Calls on the telkom SIP/5000 are costing on outgoing calls.
    Please see our call list page.
    Report pulled for trunk.
    Trunk Line configuration.
    The only difference is my exchange info which is as follows.
    Please provide your tng.ini and rules.ini
    tng.ini can be located in :
    /opt/datatex/tng
    rules.ini can be located in :
    /opt/datatex/tng/plugins#
Postby Dcdata » Tue Sep 17, 2013 8:49 am
Hi
I have attached the requested files
Dcdata
Postby John Richard Procter » Mon Sep 23, 2013 2:54 pm
Dear Dc Data
I have used your .ini and rules.
My sip trunks which are costing with your data and trunks provided.
Please see below:
Please add tng logs that we can see if any errors are being logged.
Kind Regards
John-Ri Procter
Next
