Extension Detail Report
Postby ravi » Thu Feb 20, 2014 9:46 am
Hi There
please help me with excel reporting on TNG live. i have attached images for excel and web interface report.
i would like to export into excel just like web interface format.
please find attached screenshots.
ravi
Re: Extension Detail Report
Postby Belinda Frick » Thu Feb 20, 2014 11:54 am
TNG has a 'CSV Export' option. This is a comman delimited CSV file. The CSV file can be opened in Excel, but is not for Excel specific.
The CSV export does not have the same display format as the TNG html report. It simply contains all the information used to create the html report. This allows you to format data as per your requirements outside TNG.
The CSV export format is fixed and cannot be changed in TNG. The CSV fields will also be different depending on the TNG report you export to CSV.
Please Note:
All total costs on the report will be excluded when it is exported to Excel as this will allow the user to add totals as per their preference using Excel's functionality.
If you need to see details of individual calls made, you will need to use the Extension/User Detail reports and not Department Summary by User/Extension.
Postby ravi » Mon Feb 24, 2014 9:32 am
so you saying the CSV report that i have attached is correct format? I never use to get that type of report when exported into CSV.
ravi
Postby Belinda Frick » Tue Feb 25, 2014 1:41 pm
The TNG export to CSV feature was introduces in TNG version 1.0.2.0,
the format has not changed since then (dating back to 2007).
When you import the comma delimted CSV file into Excell you need to select that the file has a delimiter and specify it as comma delimited, else it will import the entire string in one column in Excell instead of placing each comma delimited field in a seperate column.
