Cannot see extension Names
Postby cvermeulen » Tue Jan 27, 2015 1:14 pm
Hi all,
When connecting to TNG and click on extension it doesn't display anything only the edit/delete button, but when going into users/pin codes everything is there so the client cannot add, delete or edit extension numbers
Chris,
cvermeulen
Re: Cannot see extension Names
Postby Belinda Frick » Thu Feb 19, 2015 2:20 pm
Sounds like your user file has corrupted.
With all the load shedding we suggest to put the PC on a UPS and also schedule it to shutdown before the UPS power runs out.
You will need to blank the user file and enter / re-import the user again. For steps to blank the file and import refer to forum post: Not all my users are listed - please add user on call list
Postby Belinda Frick » Thu Feb 19, 2015 2:21 pm
If you are using extension and not pin codes, use the link:
How do I import extensions from a file into TNG?
