TNG Intermittantly not billing 086 Numbers
Postby conrad13 » Fri Feb 27, 2015 1:29 pm
Good day
The client is running TNG 1.1.1.12 with newest Telkom rates update. They are using a Aastra 470 Pabx.
Intermittently when client phones a 086 number, the call does not get costed.
I have attached a ext detail report for February, as well as raw data for February 2015. Also attached is a spreadsheet showing not billed numbers.
Thank you
conrad13
Re: TNG Intermittantly not billing 086 Numbers
Postby Luanda_Junzi » Fri Feb 27, 2015 2:27 pm
Good day Conrad.
Please refer to this forum page, for the TNG updates.
This update include all the area codes.
TNG Telkom 2014 Rates Update
Luanda_Junzi
Postby conrad13 » Tue Mar 03, 2015 8:12 am
Good day Luanda
We have had this problem before as well, spoke to Leon and Lee. After they tested they then released a new telkom rate book update as you refer to. We did install it at client but id did not resolve the issue.
Kind regards
Conrad
conrad13
Postby Leon van Heerden » Tue Mar 03, 2015 10:30 am
Hi Conrad,
I just took a random 086 number from one of your reports and tested it and it works here.
Which numbers are not working for you?
Did you check if the new calls coming in are still having the issue or did you go back and look at the historic information?
Can you please supply one of the Rawdata files from the site and we can process it into a TNG here and see if we get the same issue?
Leon
Postby conrad13 » Wed Mar 04, 2015 2:13 pm
Hi Leon
After it we did the rates update it happened again, new calls was made and same happened. it happens intermittantly
I have attached the raw data for the complete month of February for you, if you like i can email you a report of the 086 numbers pulled from TNG as well, showing 086 numbers not being billed.
Regards
Conrad
conrad13
Postby Leon van Heerden » Thu Mar 05, 2015 6:37 pm
Hi Conrad,
The data you gave was the exported TNG data after it has already been processed. I was requesting the rawdata. Even if it is only for the day that the update was done, since you say that after the update the issue occurred again. That must mean that there are more numbers that we are missing.
Leon
Postby conrad13 » Tue Mar 10, 2015 11:06 am
Good day
Please find attached raw data for the month of FEB, from client as requested.
Please let me know if u need anything else
Regards
Conrad
conrad13
Postby Luanda_Junzi » Wed Mar 11, 2015 10:38 am
Good Day Conrad.
I installed tng 1.1.1.12 ran the update above which I referred you to it.
Imported your raw data and all 086 numbers are costing. from the rawdata you gave me.
I generated a report and they are costing.
I will need you to attach tng.ini file and rule ini file
C:\Program Files(x86)\datatex\tng\tng.ini
C:\Program Files\(x86)\datatex\tng\plugins\rule.ini
Luanda_Junzi
Postby conrad13 » Thu Mar 12, 2015 1:14 pm
Good day
Please see attached files as per your request.
TNG.INI and TNG.rule
Kind regards
Conrad
conrad13
Postby Luanda_Junzi » Wed Mar 18, 2015 9:10 am
Good day Conrad.
I just simulated your TNG and is costing, can you please contact me for TeamViewer access.
Luanda_Junzi
Next
Users browsing this forum: No registered users and 0 guests
