by NDMC_ITSUPPORT » Thu May 28, 2015 9:35 am
My company is using the TNG telephone management tool to manage our reporting on the Mitel PABX and to manage a call barring limit set in place. The challenge is the monthly reports. Every month we need to manually change the dates on the calender for the user reports we have created. Is there not an intelligent script one can use to edit the schedules dates for the monthly reports?
We have to manually go per user to change the start date and end date to draw a report for every month.
Thanks
NDMC_ITSUPPORT
by Luanda_Junzi » Thu May 28, 2015 10:03 am
Good morning SUPPORT
Thank you for your query
You can select all the criteria's of the report you want then schedule it, for every month to be email to you.
on a specif date of that month. select page breaker for reports of users to be on separated pages.
Please note you should have your emails configured on your TNG , follow the post to assist to set it up.
TNG: sending report via e-mail.Can't connect to mailserverKind Regards
Luanda
Luanda_Junzi
