TNG not pulling data from Mitel PABX
Postby njlebeya » Tue Jan 05, 2016 9:54 am
Hi
Could you please help as TNG is not pulling data from PABX. Please see a log attached.
njlebeya
Re: TNG not pulling data from Mitel PABX
Postby Luanda_Junzi » Tue Jan 05, 2016 10:00 am
Thank you Njlebeya for your query.
I will investigate, quick one run this command on cmd
netstat -nba
to check if is the any other application using port 1752
Kind regards
Luanda
Luanda_Junzi
Postby njlebeya » Thu Jan 07, 2016 10:47 am
Thank I have ran the command. Please see an attachment.
njlebeya
