TNG data gone
TNG data gone
Postby refiloe » Tue Sep 03, 2019 3:30 pm
Good day Support,
Can you please assist we are having issues with tng again, most of the data is gone, like departments information and user details, is there a way we can get them or do we need to re-create them
refiloe
Re: TNG data gone
Postby Belinda Frick » Tue Sep 03, 2019 4:21 pm
Dear Refiloe
It sounds like data corruption.
Best option is to re-create the files.
REFER TO TOPIC : Not all my users are listed - please add user on call list
Re: TNG data gone
Postby refiloe » Tue Sep 03, 2019 4:36 pm
Hi Belinda,
With this client, we do not have the tnguser.dat and the tnguser.dat files, so what do we do in that case
refiloe
Re: TNG data gone
Postby Belinda Frick » Wed Sep 04, 2019 10:08 am
Dear Refiloe
Please move the available files as per forum post and then follow the import steps for
pin codes (user names):
How do I import user names and pin codes into TNG?
or
extensions (extension names):
How do I import extensions from a file into TNG?
The import will created the files:
  • tngusers.dat or tngext.dat
  • tngdept.dat
Re: TNG data gone
Postby Belinda Frick » Wed Sep 04, 2019 12:18 pm
Refiloe
RE phone conversation 2019-09-04,
the data is missing due to file corruption,
therefore the files must be blanked and re-created as per steps in the link provided previously.
Thank you
Re: TNG data gone
Postby refiloe » Wed Sep 04, 2019 12:45 pm
Hi Belinda,
If you can check on the screenshot that I have sent and the icon highlighted in yellow it keeps flickering and when hovering over it gives the following message "Asterisk is not connected"
Is there anything that we need to do from our end,
refiloe
Re: TNG data gone
Postby refiloe » Wed Sep 04, 2019 1:15 pm
Hi Belinda,
Please note that when I try to tick "Import files from file" and after applying changes, the changes don't take any effect at all,
I log in using tech password,
Can someone please remote to my PC so we can try and figure this out,
refiloe
Re: TNG data gone
Postby Belinda Frick » Wed Sep 11, 2019 4:04 pm
Dear Refiloe
Your TNGLive is in Free mode (not locks on some functions).
On HOME page,
click on TNG Registration and Activation.
Click on CHECK ACTIVATION button.
Re: TNG data gone
Postby refiloe » Thu Sep 26, 2019 9:51 am
Hi Belinda,
I have attached the log file,
refiloe
Re: TNG data gone
Postby refiloe » Thu Sep 26, 2019 9:52 am
Hi Belinda,
Regards
refiloe
Next
